Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Exterior Light
Turn Signal
Relay
2000 Ford Explorer TURN SIGNAL
2000 FORD EXPLORER
93,000 MILES • 6 CYL • 4WD • AUTOMATIC
JPATTON0226
MEMBER
1 POST
wHY DID MY TURN SIGNALS STOP WORKING BUT MY HAZZARD LIGHTS STILL WORK? IT'S NOT A FUSE OR A RELAY THEY WERE ALL CHECKED. wHAT COULD IT BE?
Mar 25, 2009 at 4:58 AM
Experienced Mechanic
Hi:
Have they totally stopped? Do they turn on and not flash or flash really fast?
let me know.
Mar 25, 2009 at 5:53 AM
BRUCETR
MEMBER
1 POST
How do I acces the flasher module to replace it? Remove the upper and lower steering wheel covers, or remove the panel above the driver's feet?
Jan 12, 2010 at 3:57 AM
You should be able to access it from under the dash.
Jan 12, 2010 at 5:25 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
