2000 Ford Explorer trouble code information
118,600 MILES • 6 CYL • 4WD • AUTOMATIC
CHEVYGALE
what is the falt code information for falt codes po174 system two lean bank 2 & falt code po171 system two lean bank 1
Jan 6, 2010 at 2:54 PM
  • 75,988 POSTS
Lean fuel condition: P0171/P0174
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Jan 6, 2010 at 6:40 PM
CHEVYGALE
im now a widow. and with out him here any more it is so hard to go on. but thanks to u guys u have made my day! u told me what to ck for and my son fixed it.i can now drive to my doctors with out buggen any body for a ride.THANK U SO MUCH AGAIN! debbie
Jan 7, 2010 at 3:53 AM
