2000 Ford Explorer timing
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANDREAXAVIAN
Setting the timing on a 2000 Explorer XLS 4.0 SOHC. Any tools that can be bought?
Oct 11, 2009 at 3:08 AM
MERLIN2021
  • 17,250 POSTS
Timing is not adjustable, IGNITION TIMING GASOLINE ENGINES Except Villager (EEC-V) Manufacturer does not recommend checking timing as false readings are common and timing is not adjustable. Timing specification is for reference purposes only. See IGNITION TIMING table. NOTE: EEC-V PCM has 104-pin connector.
Timing is 8-10 BTDC
Oct 11, 2009 at 3:16 AM
