When I go to start my car the car will not turn over. THis is only happening after the car has been turned off for more than 12 hours. It has power since I have full lights and radio. I then jump the car it will start right away. Sometimes I will pump the gas before starting the car and then it will turn over. I am trying to figure out if this is a fuel pump or electrical. I had a full tune up and they did change my gas filter which was very bad and dirty. Just not sure why sometimes it starts and others it will not. Any idea???? Someone did check the fuel pressure and it was fine, but this was one of the days the car started right up. SOmetimes it will go 2 days starting right up and then others I will have to jump it.
Feb 1, 2010 at 5:59 AM
