2000 Ford Explorer stalls
121,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROWSHERE
ford dies after 2 to 3 hours of running good. It coughs pukes etc. at that time. Please help
Nov 1, 2010 at 2:40 AM
  • 75,988 POSTS
Do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Nov 1, 2010 at 4:18 AM
