Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Lean
2000 Ford Explorer running lean
2000 FORD EXPLORER
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
MZAVALA85
MEMBER
1 POST
what could cause my explorer to run lean and how can we repair it?
Jul 2, 2010 at 9:33 AM
Experienced Mechanic
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Jul 2, 2010 at 10:12 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
