2000 Ford Explorer regulate of heat temp.
92,000 MILES • 6 CYL • 4WD • AUTOMATIC
LEE WARD
I have the automatic heat / air control. The operation of defrost, heat and vent operations are correct, The control of the temp does not change. @ 60 degree the temp is the same as at 80 degree. **note heat works fine**
Jan 8, 2010 at 9:39 PM
  • 110,251 POSTS
Chances are the temp sensor (under the dash) is bad. Not a fun job.
Jan 9, 2010 at 5:25 PM
