2000 Ford Explorer Putt Putt
199,500 MILES • 6 CYL • 4WD • AUTOMATIC
JESBATE66
When I put the gas on while driving the car will go putt putt, like it isn't getting the gas to keep going. If I don't hit the gas the car runs great. Can you help?
Dec 23, 2009 at 10:54 AM
  • 110,248 POSTS
HAs the check engine light come on? If not, when was the last tune up with a fuel filter? Also, I recommend checking fuel pump pressure and checking for vacuum leaks. Here is a how to for checking fuel pressure. You will need a pressure gauge. Most parts stores will lend or rent them to you.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find, and if I don't hear from you within a couple days, happy holidays.
Dec 23, 2009 at 4:54 PM
