2000 Ford Explorer PCM Codes
2000 FORD EXPLORER
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
MAILINGLIZ
I had PCM codes 402, 1405, 171 and 174
The DPFE sensor was replaced along with a vaccuum line, the car passed inspection but then the light came back on.
Also, I have an ABS light on but the ABS was checked and appears to be fine
Jan 14, 2010 at 11:15 AM
BMRFIXIT
  • 19,053 POSTS
ABS light on
have to check for codes
an OBDII reader will not access the ABS codes need to have a scanner to do so
as for the check engine light have to check for codes
do you have the same codes ??
Jan 14, 2010 at 12:19 PM
