2000 Ford Explorer pause when accelerating from stop
12,450 MILES • 6 CYL • 4WD • AUTOMATIC
REVABE
Sometimes it seems like there's a pause when you stop for a stop sign and then accelerate. Then it kicks in . It only seems to happen occasionaly. Sometimes it just doesn't seem to grab right away. It's just a little pause but a pause.
Feb 15, 2008 at 9:36 AM
  • 75,988 POSTS
Check the fuel pressure and test the throttle position/MAP&MAF sensors then report back what you've done in regards to above components.
Feb 15, 2008 at 11:10 AM
