2000 Ford Explorer p0172 p0175
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
MFBOLTON
The car runs fine 90% of the time but occasionally when you start it it wont idle, you have to drive it witht he gas and brake to keep the rpm's up. get it about a mile or 2 down the road, it seems to clean out and runs perfectly again, when it does this the MIL is not lit and no codes, it just started randomly popping a p0172 and p0175 system too rich bank 1&2, had a k&n filter in it replaced it with a paper and used CRC Mass Airflow sensor cleaner on the airflow sensor, any other ideas?
Jul 28, 2010 at 8:33 AM
  • 75,988 POSTS
Clean out the idle air control valve and EGR/ PCV valves and test throttle position sensor-
Jul 28, 2010 at 8:52 AM
