Oil gauge is acting funny, it will be fine and then sometimes it just goes to nothing but the motor sounds and runs fine.
Jan 25, 2010 at 4:13 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
BLUELIGHTNIN6
CAR REPAIR CONTRIBUTOR
The oil pressure switch at left side of engine block. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Jan 25, 2010 at 4:14 PM
2CP-ARCHIVES
MEMBER
2002 Ford Explorer mileage: 45,000. Where is the oil sending unit located on this model?
Mar 7, 2019 at 3:22 PM
(Merged)
2CP-ARCHIVES
MEMBER
The oil pressure-sending unit should be next to the oil filter.
(Merged)
LINDA_COLE03
MEMBER
I am looking for a detail diagram as to where I can locate the oil pressure switch, can you help me with this. it is a 6 cylinder motor. I bought the part because I am get erratic readings on the gauge now I have no idea as to where it goes, is it next to the oil filter and if so, where?
(Merged)
What liter engine ?
(Merged)
FIXITMR
is that a 4.0?
Mar 7, 2019 at 3:23 PM
(Merged)
LINDA_COLE03
MEMBER
I do believe it is a 4.0 engine
(Merged)
FIXITMR
ok all i can find right now is this. it's right by/behind power steering pump. hope it helps
Image (Click to enlarge)
(Merged)
FIXITMR
found another.
(Merged)
BREADMANJOHN
MEMBER
1 POST
Oil pressure sticks with cold start,after a few seconds it jumps up to normal.
(Merged)
DOCFIXIT
Next to power steering pump in block
(Merged)
FIXITMR
if you see blank image(thumb)click anyway it should pop. my internet glitched on me.
(Merged)
JDL
It should be next to the power steering pump.
(Merged)
LINDA_COLE03
MEMBER
Thank you very much. I do believe this is going to help me find it. I appreciate your assistance.
(Merged)
RIVERMIKERAT
Linda, were the images helpful? Did you get the oil pressure sending unit changed out?
(Merged)
MEONEIL
MEMBER
1 POST
Engine problem
2001 Ford Explorer 6 cyl Four Wheel Drive Automatic 100K miles
Can you tell me where the oil pressure sending unit is located?
(Merged)
The engine oil pressure switch is located on the engine next to the power steering pump-see below
(Merged)
STUKNBAMA
MEMBER
Where is the oil sending unit on a 2001 Ford Explorer with the v6 OHC?
I know it needs replacing, but can't locate it.
Thanks in advance
(Merged)
STUKNBAMA
MEMBER
ANYONE out there?
(Merged)
STUKNBAMA
MEMBER
Does anyone have any idea on where this is located?
(Merged)
LOVESCARS
usually on the block semi close to where the oil filter is located it will look partially like a spark plug with a wire on top. If may also be leaking motor oil if no good.
(Merged)
PERKINS1982
MEMBER
1 POST
where is the oil sending unit located on a 1995 ford explorer xlt 4.0 liter v6
(Merged)
It is located next to the power steering pump on the block, see pic for general view.
Mark (mhpautos)
(Merged)
XWICKEDXLULLABYES666
MEMBER
Engine Mechanical problem
2000 Ford Explorer 6 cyl
where can i find the oil sending unit in my car?
(Merged)
It should be near the oil filter. If you can't find it, let me know and I'll try to find a picture.
(Merged)
MEMBER
[quote:2502234ef1="Jacobandnickolas"]It should be near the oil filter. If you can't find it, let me know and I'll try to find a picture.
Joe[/quote:2502234ef1]
ok we found it and we bought a new one but they sold us the wrong one. we have no clue exactly what one we need...
(Merged)
OCRIM504
MEMBER
Where is the oil pressure sending unit located and is it difficult to change?
(Merged)
If its a 302CID/5.0L engine its located next to the power steering pump and its not a difficult job to do.
(Merged)
JOERACCIO
MEMBER
1 POST
Where is the Oil Pressure Sensor Sending Unit located on 1996 Ford Explorer?
(Merged)
it's under the hood, lower engine area, above oil filter, mounted in lower driver side of engine block. Here is a picture of it. THe picture is for a car that has a gauge. If you only have a light, it looks very similar, but has some minor differences.
Let me know if this helps.
(Merged)
DHAMILTON
MEMBER
Engine Performance problem
1996 Ford Explorer Four Wheel Drive
where is the oil pressure sender?
(Merged)
ROB2008
Find your engine below .
* 2.3L, 2.5L engine-left side rear of the engine, below the cylinder head
* 3.0L engine-top front of the engine, on the intake manifold
* 2.9L and 4.0L engine-top left front of the engine, on the intake manifold
* 4.0L SOHC engine-top front of the engine, on the intake manifold
* 5.0L engine-top front of the engine, on the left-hand side of the camshaft synchronizer.
(Merged)
HOTMINNIE
MEMBER
1 POST
where is the oil sending switch located?
(Merged)
BMRFIXIT
Its on the engine
almost next to the power steering pump
good luck
(Merged)
DNDC16
MEMBER
1 POST
My Oil gage keeps bouncing up and down when I am stopped or the rpm drop below 1000. I have been told that the oil sensor/sending unit might be bad. I could not locate it. Any ideas?
(Merged)
BLACKOP555
it could be the sign of a possible failure of the sending unit or a loose wire, but most likely the pump is going, i would take it in and have the oil pressure tested to make sure everything is functioning properly
(Merged)
DONCAT
MEMBER
1 POST
Where is the oil sending unit on a 2001 Ford Explorer Sport with a v6
Mar 7, 2019 at 3:24 PM
(Merged)
CHEVY22
HI
the oil pressure sendind unit is located on the engine next to the power steering pump , the low oil/tem sensor is on the left side of the engine at the oil pan
