2000 Ford Explorer OIL GAGE
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
YILDIRAY
when i started the car. oil gage do not move.i am thinking i have oil sensor problem.when i drive couple miles it goes up. HOW I CAN CHANGE OIL SENSOR
Dec 7, 2009 at 5:48 AM
RICKMAR
  • 170 POSTS
Start by taking the drivers side tire off and remove the rubber splash guard inside the wheel well. Look in from the wheel well. The red arrow indicates the oil sender right on the side of the engine block with the single white/green wire coming out of it. Unplug the connector.
https://images.2carpros.com/forum/automotive_pictures/433905_Drivers_side_wheel_well_1.jpg
Unplug and unscrew it using a deep socket.
https://images.2carpros.com/forum/automotive_pictures/433905_Oil_sender_unplug_1.jpg
New oil sender
https://images.2carpros.com/forum/automotive_pictures/433905_Oil_Sender_1.jpg
Put a little plumbers "Teflon" pipe tape or silicone "High Temp." RTV on the threads before installing to prevent any oil leakage after installation. Screw it in by hand, then tighten completely with the removal socket. Put everything back in reverse order. Plug connector back on new sender, replace the splash guard at drivers wheel well, put on your tire, torque down the lug nuts. Your all done, start it up and your oil pressure gauge will work like new. Good Luck; Rick
Dec 7, 2009 at 11:51 AM
