Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Exterior Light
Headlight
Dimmer Switch
Replace/Remove
2000 Ford Explorer no bright lights
2000 FORD EXPLORER
115,000 MILES • 6 CYL • 2WD • MANUAL
IAHUNNY42
MEMBER
1 POST
I replaced the bulbs and i still don't have high beams.Is it dimmer switch or headlight switch problem?
Mar 5, 2009 at 2:20 AM
BLACKOP555
Experienced Mechanic
with dimmer switch pulled towards you and held do they come on?
does teh high beam indicator in the dashwork? do the lights go o when the high beams turn on or do the lowbeams just stay on?
Mar 8, 2009 at 6:06 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
