I replaced both front calibers and pads because one of the calibers was losing fluid. After replacing I can not get a brake pedal. I have bleed all calibers but still no brake pedal. The fluid coming out of the calibers is clean and clear. It just does not have the presure to move the calibers. I have also replaced the master cly. and rebleed the complete brake system. the ABS light is on. I also checked for other leaks.
Thanks for your help,
Ron
RonHancock@aol.com
Ron
RonHancock@aol.com
Dec 19, 2008 at 3:14 PM
