Will a transmission from a 1999 Ford Explorer, 6cyl - 4.0 auto, 4wd match up with a 2000 Ford Explorer, 6cyl - 4.0 auto, 4wd?
May 3, 2010 at 12:48 PM
✓Experienced Mechanic
We always recommend direct fit parts. However, just make sure all the sensors on the engine are in the same place and will transfer to the engine you will be using. As far as fit, it should go right in.
