2000 Ford Explorer lots of coolant with the oil?
167,000 MILES • 6 CYL • 4WD • MANUAL
MCCRTYPL
Hello, this question regards a 2000 ford explorer xls 4.0 sohc. I have lots of antifreeze that went in with my oil quickly, it was within 25 miles. Would this be my engine oil cooler?
Feb 15, 2010 at 2:28 AM
  • 110,248 POSTS
Chances are there is a head gasket leak. Complete a compression leak to see if there are any weak cylenders. Here is a how to:
https://www.2carpros.com/dia/how_to_check_compression.htm
let me know what you find. Also, remember if you have coolant mixing with the oil, it will cause bearing damage, so I don't recommend driving it like that.
Feb 17, 2010 at 1:20 AM
