Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Stall While Driving
2000 Ford Explorer improper idle
2000 FORD EXPLORER
119,000 MILES • 6 CYL • 4WD • AUTOMATIC
PAMELA MINTON
MEMBER
1 POST
what could cause the idle to stall the engine?
Feb 15, 2010 at 3:52 PM
Experienced Mechanic
Has the check engine light come on? Have you checked for vacuum leaks? Does the vehicle run good other than the idle problem?
Feb 17, 2010 at 12:50 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
