Electrical problem
2000 Ford Explorer 6 cyl Two Wheel Drive Automatic
I have a 2000 ford explorer with a 4.0. I changes the idle air control valve, MAF, and had a complete tune-up. My problem is that the truck revs, (idles very high) at times and then almost dies, then repeats the process again and again. What could be causing this, Also not vacuum leaks.
Mar 13, 2010 at 12:30 PM
