2000 Ford Explorer IDLE PROBLEM
166,000 MILES • 6 CYL • 2WD • AUTOMATIC
LWDOZIER
IN COLD WEATHER AFTER START IDLE GOES TO 2000 RPM THEN DROPS DOWN TO 300 RPM AND ACTS LIKE ITS TRYING TO RUN ON TWO CYLINDERS. RUNS BETTER AS ENGINE WARMS UP??
Apr 4, 2008 at 5:06 PM
BLACKOP555
  • 10,386 POSTS
sounds like the MAF sensor and IAT sensor should be cleaned.
if that does not fix the problem, change your coolant temperature sensor.
Apr 9, 2008 at 9:34 AM
