2000 Ford Explorer hum in right front wheel
122,585 MILES • 6 CYL • 4WD • AUTOMATIC
HOBKNOB
i haVE A HUM THAT SEEMS TO BE GETTING WORSE COULD IT BE A BEARING AND IF SO HOW EASY IS IT TO REPLACE. THANK
Feb 13, 2009 at 4:04 AM
  • 110,251 POSTS
Hi:
It could be the hub bearing. Does the sound change when turning? If so, on a scale of 1 to 10, I would rate it a 7 to replace. If you have a good shop manual for the car, you should be able to do it if you take your time.
Feb 13, 2009 at 12:13 PM
