Can I change the shocks from underneath, orwill I need to go under the hood, and inside the cargo area
Sunday, July 6th, 2008 AT 9:23 PM
BLACKOP555
MECHANIC
Do you have a strut model? If so you can take out the assembly but you wont be replacing the shock unless you have the proper tools and a spring compressor.
It unbolts from the top under the engine compartment, and under, BEHIND the tire.
SPONSORED LINKS
Monday, July 7th, 2008 AT 9:05 AM
CORNPATCH1943
MEMBER
No struts, it has shocks all around
Monday, July 7th, 2008 AT 9:29 AM
BLACKOP555
MECHANIC
Turn of air suspension switch, raise support vehicle and support lower control arm
then remove the upper shock nut wash and insulator then remove the lower retaining nuts, compress and remove it.
