Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine Cooling
Water Pump
2000 Ford Explorer HOSES
2000 FORD EXPLORER
156,000 MILES • V8 • 4WD • AUTOMATIC
PARTHY
MEMBER
1 POST
THE HOSE CONNECTED FROM THE THERMISTAT TO THE WATERPUMP. IS IT A FORM FITTED HOSE OR IS IT A WAY TO BEND THE HOSE WITHOUT KINKING IT?
Sep 9, 2009 at 2:26 PM
Experienced Mechanic
It is form fitted. If you get a straight one and try to bend it, it will kink and cause problems for you.
Sep 10, 2009 at 1:22 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
