How do you remove the passenger side headlight bulb
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
VOODOO2NO
How do you remove the passenger side headlight in order to replace it? It is not just the bulb, the headlight is holding condensation and burning out the halogen bulb. Thanks
Nov 24, 2009 at 11:29 PM
RICKMAR
  • 170 POSTS
To Remove the headlamp assembly. Follow these steps : Compress the self-locking tabs. (1) Remove the headlamp assembly. (2) Disconnect the electrical connector. (3) Here is a sketch.
https://images.2carpros.com/forum/automotive_pictures/433905_Headlight_1.jpg
Installation To install, reverse the removal procedure. I hope this information helped; Rick
Nov 25, 2009 at 10:27 AM
