car crangs in morning first time fine, when you drive sstop and restart it spins but not crank do a recrank three times an finally runs with no problems car has good power idles fine does not smoke or ever die i have replace fuel pump and filter twice in last 5 months also fuel pump relay. pump does not run with ign on i thought it was supposed to run for a bit with just switch on, till it doas not see engine crank mode iwas planning to change ign switch. car has 65 psi fuel pressure when running but o till crnk turn over
Dec 28, 2008 at 12:44 AM
