The PO303 code indicates a misfire on #3 cylinder. This can be caused by the plug, wire, coil pack, or injector for that cylinder.
The PO171 and PO174 are indicating a lean condition on bank #1 and bank #2. This points to the mass air flow sensor. Check for air leaks between the sensor and the throttle body. Also check for air leaks or vacuum leaks around the engine.
The mass air flow sensor controls the mixture according to the airflow passing through it. Any external air or vacuum leaks will cause a lean mixture condition.
SPONSORED LINKS
Sunday, January 11th, 2009 AT 5:04 AM
