2000 Ford Explorer GAGES
120,345 MILES • 6 CYL • 4WD • AUTOMATIC
JENNIFERHART5
MY CHECK GAGE LIGHTS COMES ON AND MY OIL GAGE AND HOT AND COOL GAGES GOES TO 0. THE OIL LIGHT SHAKES A LITTLE BEFORE IT DROPS. Car has oil and coolant.
Oct 8, 2008 at 10:51 AM
KERENSELF
  • 54 POSTS
Hi Jennifer.
There are separate sending units (or sensors) for both of these gauges. If the temp gauge NEVER goes up from 0, I would suspect that the sending unit is bad or has lost connection. Similarly with the oil pressure sending unit - If it stays bottomed out, we either have absolutely no oil pressure, or the sensor is just not working. There is also a possibility that it is a wiring issue.
If you want to attempt to repair this yourself, I would start by getting a repair manual. Haynes and Chiltons are the most common. If you have to replace both sending units, I would estimate the temp switch to be around $15 and the oil switch $25-30?
Oct 13, 2008 at 3:42 PM
