2000 Ford Explorer front door panel removal
132,000 MILES • V8 • AWD • AUTOMATIC
DALLEN7828
Please help!
I'd like to replace the door latch (which I've already purchased) in the drivers side front door.
The question is: How do you remove the front door panel without breaking or damaging anything. Are there any unusual requirements to removing and installing the new latch?
Thank You!
Feb 23, 2008 at 5:05 AM
MASTERTECHTIM
  • 4,750 POSTS
i believe this door panel you have to pull straight up and it has hooks that hold it on. just unscrew the screws holding it on then lift up and it should un hook.
Feb 23, 2008 at 5:22 AM
DALLEN7828
Thanks for the info Tim!
D
Feb 25, 2008 at 4:40 AM
