2000 Ford Explorer Floating and Swerving
210,000 MILES • 6 CYL • 4WD • AUTOMATIC
ZIROZOKSCOTT
  • 6 POSTS
My wife was driving on the highway and the truck swerved to one side, and vibrated. I took it for a test drive and it seems to float as im driving in a residental street. Im thinking it is ball joints.
Aug 6, 2010 at 4:37 PM
  • 31,937 POSTS
This could be a number of items in the system steering or suspension, regardless this is very dangerous, so i would get a qualified mechanic to inspect this as there is specific methods for checking wear in ball joints and tie rod ends, get this done ASASP.
Mark (mhpautos)
Aug 6, 2010 at 5:19 PM
ZIROZOKSCOTT
  • 6 POSTS
Thanks for the reply. Ya i think it is probably the tie rod ends and yes it is going to the mechanic first thing in the morning. One tie rod rotates with my hand and the other will not, is this a problem?
Aug 6, 2010 at 5:23 PM
  • 31,937 POSTS
If you rock the steering wheel and feel the free play, you will see and side motion in the tie rod end, it is a ball socket so you want on side free play or up&down free play, a little looseness as it rotates is not a problem.
Mark (mhpautos)
Aug 6, 2010 at 5:28 PM
ZIROZOKSCOTT
  • 6 POSTS
Well im not sure. But when i was driving it and lightly rock the steering , the truck was sort of floating back and forth.
Aug 6, 2010 at 5:32 PM
  • 31,937 POSTS
Could well be a tie rod end, let me know what the mechanic report.
mark (mhpautos)
Aug 6, 2010 at 5:34 PM
ZIROZOKSCOTT
  • 6 POSTS
Ok thanks for your replies. I did have the ball joints done 5 months ago, so shouldnt be those. Will keep you posted.
Aug 6, 2010 at 5:36 PM
ZIROZOKSCOTT
  • 6 POSTS
I guess the mechanic said it is the left front Stabilizer kit. So getting that replaced and the front shocks The Stabilizer kits is just over 25$ plus hour labour. and will need an alignment.
Aug 7, 2010 at 3:42 AM
  • 31,937 POSTS
Hi there,
i would be more inclined to be thinking that if the shockers are faulty this will be the main concern, but getting all that done is a good idea and it should fix your problem.
mark (mhpautos)
Aug 7, 2010 at 11:31 AM
ZIROZOKSCOTT
  • 6 POSTS
Hey
Well it seems to have fixed the problem. I think it was probably time for some new shocks. Probably will need some new shocks on the back. That will come later.
Thanks again
Scott
Aug 7, 2010 at 2:28 PM
