2000 Ford Explorer EXPLORER 2000
107,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARCOVF
WHEN I START THE TRUCK IN THE MORNING OR WHEN BEEN OFF FOR LONG PERIOD SHAKE THE ENGINE AND GET OFF BUT ONCE I START TO PUSH THE PEDAL TO GET TO THE NORMAL TEMPERATURE THE ENGINE START TO WORK PROPERLY WHAT IS CAUSING THIS PROBLEM
Jun 27, 2010 at 5:27 PM
  • 110,248 POSTS
Is it a 4 cylender? If so, has the timing belt ever replaced? Have you checked for vacuum leaks? Has the check engine light come on?
Jun 30, 2010 at 5:01 PM
MARCOVF
i scan and the problem is the oxigen sensors but they said will not afect the engine perfonmnace but i guess is the valvule ralidik
Jul 1, 2010 at 7:09 AM
  • 110,248 POSTS
YES, the O2 sensor plays a big role in engine performance.
Jul 1, 2010 at 1:53 PM
MARCOVF
i scan the car and one of the sensor is not working properly and i guess need to change but said they are 4 sensors and i i just can faid 3 can u tell me where are the 4 sensor i dismiss one ?
Jul 2, 2010 at 7:34 AM
  • 110,248 POSTS
The V6 has 4 sensors. I was thinking the 4 cylender only had 2. Regardless, they between the exhaust manifold on the engine and the catalytic converter.
Let me know what you find.
joe
Jul 2, 2010 at 12:48 PM
MARCOVF
ok theres 2 types of sistem one for the 4L sohc and 4L EI my quiestions are both have 4 sensors
Jul 5, 2010 at 5:38 AM
  • 110,248 POSTS
Now it makes sense. Your original post said it was a 4 cylender not 4 liter V6. Yes, both have 4 sensors. on each side, there is one near the exhaust manifold and at the converter.
Sorry for the missunderstanding.
Jul 5, 2010 at 1:21 PM
