2000 Ford Explorer engine lean
147,600 MILES • 6 CYL • AWD • AUTOMATIC
DANA-DANE
My check engine has been on for a while. It was diagnosed origianally as an CO sensor. I recently had the transmission replaced (used). My car started running really off afterwards. The oil indicator goes to low when I initally start the car, then rises to mid point after a few minutes of running. I took the truck into and the the auto repair shop and the code showed "engine lean" what is engine lean and would the oxg sensor have an impact on it?
Feb 3, 2009 at 1:40 PM
ZACKMAN
  • 4,202 POSTS
There are a few codes that will point to engine lean. We need the exact code number(s).
Feb 3, 2009 at 4:06 PM
