2000 Ford Explorer Engine Hesitation
2000 FORD EXPLORER
113,000 MILES • 6 CYL • 4WD • AUTOMATIC
KSMITH0110
My truck hesitates under acceleration around 45-55 mph. It runs fine but uses a LOT of gas. I just replaced the motor with a 9000 mile motor. It's giving me P1131 & P1132 codes. I've checked the catalytic converters and the EGR valve operation. Like I said it runs fine except for the hesitation and the gas guzzling.
Mar 16, 2008 at 7:34 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
you need to look at the o2 sensors
P0131 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 1)
Mar 17, 2008 at 7:44 PM
KSMITH0110
I took it to a qualified mechanic in my area - rather than throw parts at it. It turned out to be a bad O2 sensor. He said that it showed a negative voltage reading back to the computer. With that changed, the truck runs perfectly.
Mar 19, 2008 at 7:39 PM
