2000 Ford Explorer cranks , no buzz from fuel pump, will s
MOW123
Engine Mechanical problem
2000 Ford Explorer 6 cyl Four Wheel Drive Automatic
can something else stop the fuell pump from not working.
I have had a problem off and on all year, cranks & no start. Had to turn ingnition key back & forth a few times before it would start before.
Oct 25, 2009 at 10:18 AM
CARLIFE65
  • 200 POSTS
sounds like a bad ignition coil
Oct 25, 2009 at 11:23 AM
MOW123
i HAVE HOT SPARK , EXPLORER WILL START, BUT NOT WITH FUEL FROM GAS TANK
Oct 25, 2009 at 2:05 PM
CARLIFE65
  • 200 POSTS
then you have a bad fuel pump
Oct 27, 2009 at 3:57 AM
