Every morning doesnt matter the time of year although it is worse in the winter, the car wont idle on its own. I have to keep working the throttle and keep it working. It runs rough untill it reachs normal temp.
I had a tech tell me to replace the lower O2 sensors and the tpi motor, I did and didnt solve a thing.
Any ideas out there, I would really like some help.
Thanks,
Luis
SPONSORED LINKS
Saturday, December 12th, 2009 AT 7:53 AM
MECHANIC
Luis:
Has the check engine light come on? Did he check for vacuum leaks? Fuel pump pressure? EGR? Temp sensor?
Let me know. It sounds like a lot to check, but I can help you with anything he didn't do.
