2000 Ford Explorer clicking noise
86,000 MILES • 6 CYL • 4WD • AUTOMATIC
BK5243
  • 7 POSTS
ive replaced most everything that can be replaced with the brakes. still have this clicking noise that exist only when i apply the brakes on the passengers side.sounds like rotors r out of round but there new.
Mar 28, 2010 at 1:07 AM
  • 110,251 POSTS
Does it sound like the ABS is engaging?
Apr 1, 2010 at 3:43 AM
BK5243
  • 7 POSTS
no it does not sound like that the abs light is not on also
Apr 2, 2010 at 12:11 AM
  • 110,251 POSTS
This is a good one. Chances are it is something stupid that is being overlooked. If you replaced everything, there isn't anything left. Just for the heck of it, check the backing plate behind the rotor to make sure it isn't bent or rusted and bumping the rotor when you use the brakes.
Apr 2, 2010 at 5:24 AM
BK5243
  • 7 POSTS
thanx ill check that
Apr 3, 2010 at 5:25 AM
  • 110,251 POSTS
Let me know what you find, and Happy Easter.
Apr 3, 2010 at 5:08 PM
BK5243
  • 7 POSTS
not the backing plate .could the noise be traveling .from the other side or could the cv drive axle b making the noise when braking. its driving me nuts
Apr 4, 2010 at 12:45 AM
  • 110,251 POSTS
Noise can travel very easily. Check the u-joints on the drive shaft. CV joints usually make a clicking when turning.
Apr 4, 2010 at 3:26 AM
