Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Warning Lights
Check Engine Light
2000 Ford Explorer CK Engine Light code
2000 FORD EXPLORER
166,230 MILES • 6 CYL • 4WD • AUTOMATIC
KELLYANDJOHN
MEMBER
1 POST
I have a ck engine light codes are PO171. PO174 Where should I start ??
Aug 24, 2008 at 1:35 AM
BMRFIXIT
Experienced Mechanic
check intake gasket for vacuum leak
check for a vacuum leak
check PCV valve and hose
Aug 24, 2008 at 11:11 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
