9 times out of 10 cleaning the MAP does the trick. Sorry it did not work for you.
Other possible P0303 Causes
A code P0303 may mean that one or more of the following has happened:
What you have already done has been eliminated from the list.
* Faulty oxygen sensor(s)
* Faulty fuel injector
* Burned exhaust valve
* Faulty catalytic converter(s)
* Poor compression
* Defective computer
I hope you can track down the problem at little expense.
Good Luck;
Rick
Wednesday, December 30th, 2009 AT 12:16 AM
