2000 Ford Explorer CHARGING SYSTEM
TIMETOWASTE
Electrical problem
2000 Ford Explorer 6 cyl Four Wheel Drive Automatic
I'VE REPLACED THE ALTERNATOR WITH TWO NEW ALTERNATORS, BUT IT STILL ISN'T CHARGING.
Apr 30, 2008 at 9:54 AM
BMRFIXIT
  • 19,053 POSTS
Engine size (4.0)
you need a test light and volt meter
1. check fuses
2. check fuse no .24 in the junction box and if fuse OK
3. measure volts on Black /Orange wire at alternator B+ terminal
if no power repair short if OK
4. disconnect alternator 3 pin electric connector ,measure volts of Yellow ?White wire terminal A if no power present repair a short if OK
5. reconnect 3 pin connector turn key on measure volts of Light green /Red wire (backprobing connector here ) if less than one volts repair open or short if OK
6. start engine and ground terminal F if charging system OK know replace the voltage regulator
Apr 30, 2008 at 10:32 AM
