2000 Ford Explorer changing fluid
142,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOND12
I changed the fluid and filter @ 58 k miles. would it be o k to change it now?
Mar 26, 2010 at 3:48 AM
  • 110,248 POSTS
The trans should be serviced aprox every 30K. Thus, it may be too late to service it if you are having trouble. If there is no trouble, then you should be fine.
Apr 1, 2010 at 4:21 AM
