2000 Ford Explorer Car shakes violently
2000 FORD EXPLORER
105,000 MILES • 6 CYL • 4WD • AUTOMATIC
LUVINTOBEALIVE
Hi, I have had this truck to 4 mechanics including one ford dealership. They have replaced: ball joints, tie rod,tires,rack and pinion. the problem is still there.it started as a small wheel shake and has gotten progresively stronger. I really hope you can help.
Thank for your time
Nov 22, 2009 at 10:04 AM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
Has anyone looked at the tires? A shifted belt in the tire will cause wobble issues, what speeds and any other pertinent info does this occur?
Nov 22, 2009 at 11:06 AM
LUVINTOBEALIVE
The tires haver been replaced and are new and balanaced. Started at speeds over 50mph and progressed to where the car is undrivable at 15mph at this point
Nov 22, 2009 at 1:53 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
Has the front 4X4 axle been checked out? I once came across this in a 78 full size Bronco...turned out to be wheel beaings in the hub. And the u joints, yours has a one piece hb bearing and CV Joints, but if something broke insde the cv, it could cause a bad wobble...Seems hard to believe they cant find it when the trouble is this pronounced!
Nov 23, 2009 at 7:07 AM
