2000 Ford Explorer Can it be driven safely?
19,000 MILES • 6 CYL • 4WD • AUTOMATIC
JDCPJC
  • 16 POSTS
If there try to take into a car repair place for a front end alignment is it safe enough to drive it there? I'm 30 miles from the nearest town. If it is ball joints or tie rod ends is it expensive?
May 26, 2008 at 2:13 AM
  • 31,937 POSTS
Hi there,
This will have to be inspected first hand to determine whether its safe or not. I suggest you have a mechanic or someone with experience inspect if you are not sure. It is better to be safe rather risk a potential danger. Ball joints & tie rod ends & relatively inexpensive items, the labour component will be around 3-4 Hrs depending on how much is replaced.
mark (mhpautos)
May 26, 2008 at 10:56 AM
JDCPJC
  • 16 POSTS
thank you so much for your help. I plan on getting this resolved this week...
May 26, 2008 at 11:07 AM
