2000 Ford Explorer Blower motor
AMBERA
  • 2000 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 19,000 MILES
Do you have to take your dashboard off to get to the blower motor? If not where is the access?
Friday, January 29th, 2010 AT 12:45 PM
MERLIN2021
  • 17,250 POSTS
No open the hood and follow these instructions.
BLOWER MOTOR & FAN Removal & Installation 1. Disconnect negative battery cable. Remove speed control servo from its mounting and position out of way. Remove coolant/washer reservoir mounting bolts and position it aside. 2. Disconnect blower motor cooling tube from blower motor. Disconnect harness connector. Remove 4 blower motor mounting plate attaching screws. Remove blower motor and wheel from evaporator assembly. To install, reverse removal procedure.
Friday, January 29th, 2010 AT 12:52 PM
