2000 Ford Explorer ABS
54,000 MILES • 6 CYL • 4WD • AUTOMATIC
NARCO
Hi, At slow speeds eg, after braking at stop lights or junctions and then moving forward with foot still on brake pedal it's like treading on eggshells with the pedal crunching downwards.
Also a slight pull to the right.
New brake pads have been fitted also new ABS front left wheel sensor fitted but still problem persists. ABS warning light does not light up on dashboard.
Can you help. Thanks.
Jul 13, 2010 at 11:16 AM
  • 110,248 POSTS
Have you checked wiring to the sensors? Also, check the one that wasn't replaced to make sure there isn't a build up of dirt / grease that could cause the ABS to think the wheel is locking up.
Let me know what you find.
Jul 15, 2010 at 5:17 PM
CHARLIE7
hi just curious what you found Im having problems like that, i changed master cylinder new rotors and front pads just change a caliper on one side will change other soon but same problem also change wheel bearing hubs. let me know thanks.
Jul 14, 2011 at 7:14 PM
NARCO
Sorry charlie7, I sold it on a year ago.
Jul 21, 2011 at 1:04 PM
