vibration in Gas Pedal?
2000 FORD EXPLORER
93,000 MILES • 6 CYL • 4WD • AUTOMATIC
BUCKFAN72683
I have a 2000 Ford Explorer that just had to have a new water pump, radiator hoses, serpentine belt, and a tensioner installed. No biggie, paid the grand for it and was happy it was fixed. I started driving it home, and between the speeds of 20 and 40 mph, my gas pedal vibrates randomly. Only when im accelerating though, it stops if I let off the gas. Is there anything that the mechanic may have done, accidentally, to make this happen?
Aug 18, 2008 at 8:40 AM
BLACKOP555
  • 10,386 POSTS
This is because you have an engine misfire which can be a spark plug or ignition coil problem, Here is a guide to help you fix it.
Please go over this guide and get back to us.
Aug 18, 2008 at 10:26 AM
