2000 Ford Explorer
RCISSNE
  • 2000 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 135,000 MILES
I have changed out the dash twice, the first change the speedometer did not work, sent it back, they sent me another, I installed it same thing everything but the speedometer worked, is there something else that might be the problem? Or did I get another one that just did not work. These are used dashes, but the dealer is good.
Monday, September 20th, 2010 AT 2:37 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Maybe Vehicle Speed Sensor located on transmission. Check engine light come on? Does Trans shift good? A scan of computer while driving would show if VSS is working.
Hope this helps
Thanks for donate
Monday, September 20th, 2010 AT 2:44 PM
RCISSNE
  • 23 POSTS
The first dash panal the odometer worked, the gauges were not working properly, so it worked before I changed it out, do you have another idea?
Monday, September 20th, 2010 AT 3:27 PM
DOCFIXIT
  • 18,828 POSTS
What was fault with original dash?
Wednesday, September 22nd, 2010 AT 10:21 AM
