HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Fuel System
Fuel Pump
Fuel Pressure
2000 Ford Explorer
LAURAGRACEANN
MEMBER
2000 FORD EXPLORER
6 CYL
4WD
AUTOMATIC
115,000 MILES
What is the correct fuel pressure for a 200 Ford Explorer? Ours is running at 45 psi.
Sunday, August 3rd, 2008 AT 8:29 PM
OBXAUTOMEDIC
MECHANIC
Koeo - 30 - 65 psi
SPONSORED LINKS
Sunday, August 3rd, 2008 AT 9:44 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Fuel Pressure Content
Fuel Pressure Specifications
What Is The Fuel Pressure Measured At The Fuel Rail? I Got 30 Psi At 20 Inches Vacuum And 38 Psi At 0 Inches. With The Fuel Pump Removed...
Asked by
Lewis Judson
1998
FORD EXPLORER
2001 Ford Explorer Fuel Presure
I Have Replaced The Fuel Pump 4 Times Over The 220k Miles. I Have Installed An External Fuel Pump. A Fuel Pressure Gauge After The Pump...
Asked by
Rodger22
1 ANSWER
2001
FORD EXPLORER
Fuel Pump
Had Problems Car Died And Would Not Start No Fuel Pressure Changed Fuel Pump They Gave Me A Pfs400 Said It Was The One For This Car When...
Asked by
bipperwix
2004
FORD EXPLORER
1992 Ford Explorer Fuel Pump
When I Check Fuel Pressure Which Is Suppose To Be 39 To 40 Psi And Which It Is When I Turn Key On But When I Start Engine It Drops To 30....
Asked by
JERRY L. MCELWRATH
1992
FORD EXPLORER
2000 Ford Explorer
Well My Explorer Is Giving Me A Bunch Of Trouble. The Fuel Pump Whent Out On It And I Had It Replaced, I Got It Back And Drove It Bout 5...
Asked by
hotrod0620
2000
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Fuel Pump Replacement
Fuel Pump Pressure Test
How to fix an engine that wont start
Online car repair manuals
