1999 Ford Explorer won't start
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
JODYBETH
was running fine, then wouldn't start so I cleaned battery cables & that seemed to do the trick. Ran fine, but next time I went to start it wouldn't start. Got a jump (took a lot of tries to "jump start"). I put in new battery, but still didn't start. Someone told me probably either starter or alternator draining battery. Does this sound like the problem?
Aug 3, 2008 at 8:19 AM
BMRFIXIT
  • 19,053 POSTS
u have a new battery on
check terminals and make sure its clean and tight
check starter and solenoid
Locate starter
1st check if small wire has a good connection
make sure u have e brake on
with key off jump the two wires on the starter and it should crank if it does not replace start
Aug 3, 2008 at 3:45 PM
