1999 Ford Explorer WONT START
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
JENNIEWAGSTER
WHEN I START MY CAR IN THE MORNING I HAVE NO PROBLEM, BUT WHEN I TRY TO START IT LATER IN THE DAY, IT WONT START LIKE ITS OUT OF GAS. SOMETIMES IF I WAIT A FEW MINUTES AND TRY AGAIN IT WILL START AND OTHER TIMES IT WONT. WE LISTENED TO THE FUEL PUMP AND IT SOUNDS LIKE IT IS WORKING. COULD IT BE AN INJECTOR OR A FUEL FILTER??? OR WHAT IS ANOTHER OPTION???
May 17, 2008 at 7:39 AM
  • 75,988 POSTS
You need to determine if its fuel or ignition problem
Do below when it refuses to start has to be done quick to catch what's missing
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
May 17, 2008 at 7:48 AM
