1999 Ford Explorer washer fluid
197,000 MILES • 6 CYL • 4WD • AUTOMATIC
BONKYS
Had new windshield installed ever since then washer fluid does not come out worked fine before new windshield
Mar 9, 2008 at 9:02 AM
SERVICE WRITER
  • 9,123 POSTS
Does the pump run?
IS there fluid in the reservior?
Mar 9, 2008 at 9:05 AM
BONKYS
yes, motor is working and fluid is full. how do I make sure they connected hoses under plastic grill where wipers are?
Mar 10, 2008 at 7:21 AM
SERVICE WRITER
  • 9,123 POSTS
Well if they weren't connected it would be peeing all over from the pump pumping the fluid. Get as close to the pump as possible (ideally at the pump) and disconnect the line and energize the pump. The pump should be squirting. If it isn't the pump is bad or fluid can not get into the pump on the inlet side. If not there is a restriction further up the line. For that compressed air can probably blow through the restriction.
Mar 10, 2008 at 11:02 AM
BONKYS
It does leak fluid when turn on washer fluid. How do I access it? there is a plastic grill where wipers are and that is where it is leaking.
Mar 12, 2008 at 1:27 AM
