1999 Ford Explorer Various electrical problems w/1999 Explo
131,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHAMPIONONE
1. ABS light on instrument panel is on
2. Door ajar light on instrument panel stays on
3. Bright headlights don't come on, regular lights go off when dimmer lever is activated
4. Passenger auto door lock does not work
5. Inside lights don't go off unless inside lights dimmer switch (next to headlights) is in a certain position
Also, you have to have the column gear shift between r & n for reverse, d & 1, etc. to be in gear
Dec 29, 2009 at 1:35 PM
  • 110,248 POSTS
Have the body control module tested.
Jan 1, 2010 at 5:26 PM
